crash on close
crash on close
michaeldugger
Message 1 of 11
crash on close
michaeldugger
Help I love this product but every since I have installed this about 4 months ago without fail every single time I close the program it crashes every single time.  It is frustrating to pay so much for this program and have to go through so many error reports constantly.  Is there someone who can offer some advice?
Replies (10)
Message 2 of 11
RajkumarIlanchelian
@michaeldugger Thank you for submitting the crash error report. I could not get much information from the report but it is showing that you are on a Wacom tablet? Are there any pending updates on the machine? Graphics updates? Will look closer to see what could be happening.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 11
michaeldugger
what would you need from me to find a solution? screen records or error logs? Let me know and I will make them available. Thanks for your efforts.
Message 4 of 11
michaeldugger
Thanks in advance for your efforts.  Please let me know what would be needed to find a solution.  Error logs or screen records let me know and I will make available.
Message 5 of 11
RajkumarIlanchelian
@michaeldugger There are a few things we need to tryout here but to begin with:
1. Please let me know your machine specifications
2. Every time you get this error please do submit it to us with your email ID so that I can track it in our back end
3. Does this happen even on this simple workflow - Launch Fusion, close Fusion.
4. If not the above workflow for any other workflow does it ALWAYS crash on close. I am trying to see if there are patterns to when it will close.
5. Are you using any external devices like space mouse or a pen etc that if you disconnect is the crashes going away?
6. I see 3 customers atleast from our backend that are encountering this and hence this is more selective in terms of hardware/software and hence trying to figure where it could be.
I will likely need more info based on answers of above.
Autodesk Fusion
Join Fusion Insider
Message 6 of 11
michaeldugger
yes even just open and close it does it.  I will get your information thanks again
Message 7 of 11
michaeldugger
Device name insightfulimagery
Processor Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.20 GHz
Installed RAM 16.0 GB
Device ID E1DAE22C-5BB6-4AE9-B930-9D66C296C572
Product ID 00326-00815-61702-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Pen support
I have attached files and the system information is here.
Also yes wacom tablet used.
Message 8 of 11
RajkumarIlanchelian
@michaeldugger If you eliminate the tablet an run in only using the PC do you get the crash?
Autodesk Fusion
Join Fusion Insider
Message 9 of 11
michaeldugger
wow I unplugged tablet and no issue with crash when open and close or when I open a file and then close
Message 10 of 11
RajkumarIlanchelian
@michaeldugger Are there any pending updates on the tablet or any pending updates on the PC?
Autodesk Fusion
Join Fusion Insider
Message 11 of 11
michaeldugger
no there are none
