Couldn't finish form because of self-intersection, which can not be deleted
hanovo_gumball
hanovo_gumball
TrippyLighting
Avoid triangles at all cost! So I removed that traingle and then used  the Make Uniform tool with Convert T-Points enabled
Avoid N-Gons and use complete edge loops.
As you can see in the screenshot, that creates much cleaner surfaces.
Nice work so far. Keep going!
hanovo_gumball
Thank you so much for the solution, I think I should learn more about T-points and N-gons to avoid them
