couldn't download fusion 360(super improtant),please help me
Hi,i am a student of fy bech,i was downloading fusion 360 but in instuallation error is coming,when instuallation reach to 99% an error occur and it terminated please help me i want to submit project on 1 april before 9 pm,please help me out
logs file
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\HP\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000211B6431448> #
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\HP\AppData\Local\Temp\7zS579C.tmp\resources\buildinfo.json
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20210209142102
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2021-03-30 18:30:25,686 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\HP\AppData\Local\Temp\7zS579C.tmp\resources
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\HP\AppData\Local\Temp\7zS579C.tmp\certs.pem
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=False, connection='https://dl.appstreaming.autodesk.com/production/', force_full=False, globalinstall=False, headless=False, infofile=None, install_origin='Streamer', language='en', launch_args='', logfile=None, loglevel=20, no_auto_launch=False, no_cleanup=False, no_uninstall_registry=False, operation=<function multiple_operate at 0x00000211B6DF5288>, pipes=None, procfac=<function deploy_process at 0x00000211B6E39558>, profile=False, pull_dest=None, purge=False, quietmode=False, stream='production', threadscount=5, update_connection=None)
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2021-03-30 18:30:25,692 - MainProcess(42892) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2021-03-30 18:30:25,959 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2021-03-30 18:30:26,129 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\HP\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2021-03-30 18:30:26,132 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2021-03-30 18:30:26,286 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2021-03-30 18:30:26,286 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2021-03-30 18:30:26,286 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2021-03-30 18:30:26,308 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2021-03-30 18:30:26,640 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.192.98.68
2021-03-30 18:30:26,736 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2021-03-30 18:30:26,840 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMTkyLjk4LjY4
2021-03-30 18:30:26,840 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4xMjQ=
2021-03-30 18:30:26,840 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2021-03-30 18:30:26,840 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2021-03-30 18:30:27,352 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2021-03-30 18:30:27,352 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2021-03-30 18:30:27,376 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:27,376 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:27,376 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:27,763 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 64c98c0a-3a8d-4089-83d9-940c40562da3
2021-03-30 18:30:27,763 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.9937 for app 73e72ada57b7480280f7a6f4a289729f
2021-03-30 18:30:27,763 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2021-03-30 18:30:27,763 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2021-03-30 18:30:27,763 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [6, 1]
2021-03-30 18:30:27,771 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2021-03-30 18:30:27,883 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 60ea2a958217997f2949751c5cfb5f58737cd3f2
2021-03-30 18:30:27,883 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/60ea2a958217997f2949751c5cfb5f58737cd3f2.js...
2021-03-30 18:30:27,902 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:27,902 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:27,902 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:28,374 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/188a4e8661e1af76338ecb55b827ac46493d7388.ta... for package 60ea2a958217997f2949751c5cfb5f58737cd3f2
2021-03-30 18:30:28,374 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9dcd886691cc8c80a197499bb39814ecdc7daf7d
2021-03-30 18:30:28,374 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9dcd886691cc8c80a197499bb39814ecdc7daf7d.js...
2021-03-30 18:30:28,416 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:28,416 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:28,416 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:28,419 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:28,419 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:28,419 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:28,788 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\HP\AppData\Local\Autodesk\webdeploy\production\9b292d8eef538636fb448307b89a33246e260a1a
2021-03-30 18:30:28,788 - MainProcess(42892) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2021-03-30 18:30:28,796 - MainProcess(42892) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5c0f53a96eea25d55c269e82b1986735be0379bc.ta... for package 9dcd886691cc8c80a197499bb39814ecdc7daf7d
2021-03-30 18:30:28,796 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4940daec91ef962618d096ca6aa4d519e54b5f4d
2021-03-30 18:30:28,796 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4940daec91ef962618d096ca6aa4d519e54b5f4d.js...
2021-03-30 18:30:28,828 - MainProcess(42892) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:28,828 - MainProcess(42892) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:28,828 - MainProcess(42892) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:28,828 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:28,828 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2021-03-30 18:30:28,828 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2021-03-30 18:30:29,198 - MainProcess(42892) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\HP\AppData\Local\Autodesk\webdeploy\production\9b292d8eef538636fb448307b89a33246e260a1a
2021-03-30 18:30:29,207 - MainProcess(42892) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/08715f25d57ca202f5d7879437ab3f45c1e2229c.ta... for package 4940daec91ef962618d096ca6aa4d519e54b5f4d
2021-03-30 18:30:29,207 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bcedcd56b25d883b5629bcd0921b012cc558c98c
2021-03-30 18:30:29,207 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bcedcd56b25d883b5629bcd0921b012cc558c98c.js...
2021-03-30 18:30:29,246 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2021-03-30 18:30:29,247 - MainProcess(42892) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
Phil.E
Sorry I missed this. Did you ever find a solution?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
