corrupt file
corrupt file
corrupt file
                       I was working on a project, I saved the file and exit from Fusion 360 normally, and now am not able to open it. I am unable to open the document, I keep receiving an error message "The file you are trying to open is corrupt! The current operation will be aborted. File name:_ xxxx." I really need help accessing this document.
I've attached the link below,
https://a360.co/2X9qSVL
daniel_lyall
One thing you can do is into the cache and get the file from there just copy past it out then open in fusion https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Issue solved, thank you for your support.
