Correct Component Insert command
LiveLover
LiveLover
Insert component command allows to make a move of the component we insert in current component during insertion.
Can we see/edit this move parameters?
Thank you for any suggestions or explanations.
jeff_strater
no, there is no way to see or edit the transform you applied on Insert.  If you want the component in a different place, use a Joint to position it, or Move Component if you really just want to move it by a known amount.  Don't forget to use Capture Position to capture the new location
Jeff Strater
Engineering Director
