Copying a Line
Copying a Line
susan458
Copying a Line
susan458
This inside selected blue line forms the inner part of a flat pipe.  How could I move or copy this line to somewhere else so as I could form a plate of this shape
g-andresen
It is not necessary to copy and/or move the sketch.
You simply create a new body from the profile and move it as needed.
Screencast
günther
susan458
Even when I have selected all the lines so as they appear blue, I am unable to select the inner area to extrude it.
What are you using to make these little videos, it may be helpful if I could show this in video form.
g-andresen
Hide the body and check, if there exists a closed profile > enable "Show Profile" in the sketch palette.
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
susan458
I will upload something later as it's going to get more complicated, but to start off with just simple stuff.
For a pipe like object your method works fine if I have used "Offset" to create the hollowed interior.  But I can't achieve this when I have used the "Shell" command.
g-andresen
I hope the screencast helps.
günther
susan458
Many thanks, that is exactly what I was looking for
