Copy Sketch Objects outside of Sketch
jdaues
jdaues
I have a constrained sketch. Now I want to make a copy of it.
When outside the sketch, I select Modify > Move/Copy
Under Move Object, the only selection that is functional is Sketch Objects, so I select that
Then I window select all objects in the drawing.
This causes Create Copy to be disabled.
How do I make a copy?
davebYYPCU
From outside a Sketch you can Copy to Memory all the sketch articles. (Control / Command C)
As you only have 1 sketch in this file you have to edit it or create a second one - to paste that copy.  (Control / Command V)
Why are you copying anyway.  Make your sheet of roofing and then Pattern in the modelling window.
Might help...
jdaues
I want to get a profile that is the entire width of the roof panel and then extrude it.
