Copy/paste missing?
Copy/paste missing?
redklyde4CKN
Copy/paste missing?
redklyde4CKN
Community Visitor
Community Visitor
Did something happen to the simple copy/paste functionality?  I haven't used 360 in a while, but hopped on to model a part for 3d printing.  After it updated, there is no copy option in the context menu and Ctrl-C Ctrl-v does nothing.  The only way I can copy something is by moving it and creating a copy.  Which is alright for some things, but I can't duplicate sketches or anything.  Searching online, everything just says to ctrl-c/v or right click copy.  But those don't seem to exist.
davebYYPCU
You need something selected - then Copy will happen.
After you Copy - Paste will happen.
Might help….
luiyingchun
cntl C > cntl V works for me.  As said in the other reply, you need to select the object first
jeff_strater
"but I can't duplicate sketches or anything"
You cannot copy/paste sketches in a parametric design.  That has never been available in Fusion.  However, you also say "anything".  Does that mean if you select a component and right click, you do not see "Copy" in the context menu?
Jeff Strater
Engineering Director
redklyde4CKN
Community Visitor
Community Visitor
hmm, strange.  Well I suppose I could be crazy, but it seems to be working today.  And yes @jeff_strater , yesterday I was unable to copy bodes, components, sketch objects or anything.  Copy was never in the context menu whether using the browser or viewport.  I was having to create new sketches and align points by hand and reassigning the sketch plane.
jhackney1972
Jeff, unless I do not understand what you mean by a "parametric design", I copy and paste sketches quite often within the same sketch and between sketches.  Could you elaborate a bit on your statement?
John Hackney, Retired
jeff_strater
@jhackney1972 - you are copy/pasting sketch geometry.  I was referring to copy/pasting an entire sketch (i.e. selected from the browser):
You can copy/paste a sketch in a Direct Modeling design, though.
Jeff Strater
