Copy body to component.
tullCDMKB
tullCDMKB
Hi there.
Unless I read it wrong (not sure where I read it) I thought it was possible to copy a body in a component to another component.  But I can't find anyway to do this.
Do I need to be in non history mode for this to work?  What is the correct way to do this?
Thanks.
HughesTooling
You should be able to select the body in the browser, right click and copy then right click the destination component and paste. a word of warning, copy can break and there's no way to fix\reselect the source body, because of this I always use boundary fill, with the destination component active just run boundary fill and select the body and then the single cell. Boundary fill even has the option to create a component so can save the step of creating the component first.
Mark
Mark Hughes
Owner, Hughes Tooling
TrippyLighting
You CAN do that with the timeline enabled or disabled. But with different effects!
