Copy and paste of sheet metal bodys and components
jamesrose3WXP3
Observer Observer
jamesrose3WXP3
Observer
Observer
Not sure why you can't copy and paste sheet metal bodys and components.  if this option was available it would save me a lot of time.
jhackney1972
You should have no issue Copy and Paste or Paste New a sheet metal component.  I did both is the video.  As you say, you cannot Copy and Paste or Paste New a sheet metal body.
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
jamesrose3WXP3
Observer
Observer
Thanks John
I'm able to copy component but when i change the copied pc the original changes also is there a solution for this?
TheCADWhisperer
@jamesrose3WXP3
It sounds like you want to save as a new (different) file rather than copy.
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply for testing?
