Copied files losing associativity with bodies copied using Insert Derive.
Ironsharpmachining
Ironsharpmachining
I wanted to move a set of files (the individual parts, as well as the file that contains the assembly of those parts)--the intent being to actually Move the files, but I am always cautious and typically copy and paste files, rather than go the Cut and Paste method--just in case something goes wrong, I'd still have the original files.
At any rate, I copy/pasted some files, including an assembly, and the copied file did not point to the files copied, but referred back to the original files.
Is there a way to "re-direct" the Insert-Derived body to the correct location? I did see the option to select which version,  but not an option to choose the file, when the part was referencing the wrong file altogether....
(*my apologies; the nature of this problem seems to be difficult to describe..!)
-Joey
dsouzasujay
Hi @Ironsharpmachining ,
If you have 2 files A & B
Where B is derived inside A (A has a reference to B)
In this case, if you do a copy of A as A_Copy, then still A_Copy will be referencing to B
So, its not possible to copy the referenced files with A
If you want to do a copy process, then export the files as *.f3z and import the same to the new project\folder location.
When you do a export and import, version history will be lost.
Let me know if you are looking for same or something different.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
