Converting Splines to Lines
susan458
Message 1 of 8
susan458
I need to trace around of the edge of some silhouettes, if I use the normal lines and arcs I geta workable sketch. However I can make a much better job of the trace if I use splines.  The problem is the resulting sketch is unworkable, (I think it is too complx, 1000+ points, makes fusion lock up)
Is there a way to convert the complex spline sketch into a normal outline.
Replies (7)
Message 2 of 8
HughesTooling
Could you use Inkscape to trace for you? Also do you really need 1000 points, what are you trying to trace?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
g-andresen
The golden rule for the number of control points is: "Less is more".
Please share the file
File > export > save as f3d on local drive > attach to post
günther
Message 4 of 8
TheCADWhisperer
@susan458
Are you familiar with manipulating Spline Handles?
Do this experiment - create a Spline with just 2 points, a start and end.
Now click on the Spline and drag the Handle lengths (weights) and angles.
What do you observe?
Message 5 of 8
jhackney1972
If you have a complex segmented line, this Blog Article and Video can help you out.
John Hackney, Retired
Message 6 of 8
susan458
Many thanks for that, worked just perfectly
Message 7 of 8
susan458
Never heard of inkscape, I'm wondering if it would be helpfull in what I am trying to do.
Need to get an outline of an image into fusion so as I can create a DXF file.  They're time consuming the way I am doing them.  So as an example.  this image
https://pixabay.com/illustrations/swallows-bird-silhouette-swallow-3608071/
to this fusion drawing
attached f3d  file
(obviously I have achieved this with the help of John's suggestion above)
Message 8 of 8
jhackney1972
If you have JPG files or any other type of files you want converted, try the Convertio website, it is one of the best converting site for all types of files on the web, in my opinion
