Converting SLT to editable Fusion File
bs
Message 1 of 8
bs
I have a SLT file that I wish to import to fusion and edit.
I have followed (or tried to) many tutorials and failed miserably, so please help!
The attached STL file is that of a netball with the actual ball missing, its like the engraved part of the ball only.
I wish to add a sphere to the centre and enlarge the sphere to it intersects the stl file and so creates the ball with the stl image engraved / sunken just below the surface of the ball / sphere that I add.
I can insert the stl via mesh. but dont appear to be able to convert it and when I draw the sphere I can set its size correctly, but can not achieve the engraved line effect.
The stl is attached.
Can you help please? - Spent hours so far.
Replies (7)
Message 2 of 8
Joshua.Aigen
Hi @bs, I just had a post similar to this. This maybe one of those occasions that working with meshes is better than converting. I created a screencast on what I did check it out. Sorry about the background noise I forgot to remove the audio before uploading. Edit: Making the sphere slightly smaller will resolve the small artifacts.
Joshua Aigen
Workshop Supervisor
Message 3 of 8
jhackney1972
STL file converted and moved it to the Origin for you to use.  Model attached.
John Hackney, Retired
Message 4 of 8
bs
Thank you for the video.
I am almost completely certain i am following your video, but I don't the same result??
I am importing the original mesh and i move it to the origin.
I create a sphere of 61mm diameter which creates a new body. (61 is 1 mm larger than the mesh)
I create tesselate
I then combine.
I select the two meshes
I select cut option
I get an error - yellow triangle against the original mesh that says it does not have a positive volume and everyting disappears.
Can you provide further assistance?
Message 5 of 8
bs
Hello
Thank you for your help, I really appreciate it.
However, I am no further on :(.
I have opened your converted file and then I draw a sphere from the origin to just a bit bigger size than the "mesh", but no matter what option I choose, cut, intersect etc, I get nothing or a solid ball??
Please could you advise further?
Message 6 of 8
jhackney1972
Take a look at the Screencast.  You said you were making the Sphere a little larger than your converted mesh body, this is probably the problem.  If you want less cut in the sphere, this can be done also, I just did it with sightly less than the existing size.  Model is attached.
Message 7 of 8
bs
Hi
Thanks for the new video!!
I will try this asap and let you know.
Thankyou
Message 8 of 8
bs
Hello.
Thank you for the second video.
It works just fine!!
Thank you again.
