Converting cm to mm
Converting cm to mm
hannahX75AM
Converting cm to mm
hannahX75AM
Community Visitor
Community Visitor
I have received an object which has been drawn in cm rather than mm. Is there a way of converting the object into mm without having to redo the object?
Many thanks.
TheCADWhisperer
Is it the correct size in cm, but you would prefer to work in mm?
Or is it the wrong size in cm.
Document units or scale.
g-andresen
change the setting
günther
