Continuous crashes when moving object
m.savazzi
Message 1 of 10
m.savazzi
I continue to have infinite crashes on when I move an object.
Is not a too complex object so I need really some help.
Here the links to the two design
Object to paste to
Object to copy from
thanks in advance for your help
M
Replies (9)
Message 2 of 10
saito.kh
Autodesk Support
Autodesk Support
Hi @m.savazzi,
Thank you for posting in the community.
I am sorry to hear you are having the crash issue.  I saw this as I tried to move the sketch on my end.
At this time I suspect there might be something related to constraints with the sketch.  In order to further investigate this, I will log a report with our development team.
I will circle back here once I have more information to share!  Thank you for your patience.
Thank you.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 10
m.savazzi
Does it crash on your side too?
I've submitted more than 4 logs to try to help 🙂
M
Message 4 of 10
saito.kh
Autodesk Support
Autodesk Support
Hi @m.savazzi,
Thank you for submitting the crash reports.  I will attach them with the report.
Yes, I was able to recreate this when I tried to move all objects of "Sketch 14" in the file "Fan Dual".  If I missed something in my testing, please let me know.
As I further tested with your files, I found it did not happen if I inserted the sketch from data panel using "Insert into Current Design" instead of copy & paste.  I think it could help if you would like to place the sketch at a target position.
Thank you.
Kanehiko SAITO
Message 5 of 10
rohit.bapat
Hello @m.savazzi
Thank you for posting the problem and i am sorry that for the crashes you are facing. I have created a ticket (FUS-39345) to track this problem.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
Message 6 of 10
m.savazzi
saito.kh
thank you. In fact it does not allow me to edit the sketch but just creates a link
this creates to me a problem to have the points to be coincident.
can you help me?
Message 7 of 10
saito.kh
Autodesk Support
Autodesk Support
Hi @m.savazzi,
Thank you for the reply!
Have you tried to Break Link?  This would enable to edit the sketch, but it might happen the issue when I tried to move the sketch.  So I would break the link after I placed it to the target location.
If I misunderstood your question, please feel free to let me know - I'm happy to help!
Thanks.
Kanehiko SAITO
Message 8 of 10
m.savazzi
I will try that but the funny part is that I cannot move the linked object as I like.
It does NOT move beyond a certain point.
Also when I get back to the drawing after I've closed it... it's back to the wrong position
I use the select of the items and move them.
I tried to move the imported sketch but was not successful
Message 9 of 10
m.savazzi
I tried to break the link but the object remained alone:
sk1.pngas you can see I would have expected to have it on Sketch 16th as I need to merge it with the other object
am I missing something ?
Message 10 of 10
saito.kh
Autodesk Support
Autodesk Support
Hi @m.savazzi,
Thank you for the update!
I recorded what I was trying to do.  Can you please check it and let me know if I missed something?
Hopefully this helps.
Thank you.
Kanehiko SAITO
