Contact set model animation
JB_SGGW
JB_SGGW
Hello
I am new to the forum and newbie in Fusion.
I created two simple models of a cam mechanizm. But the problem occurred when I tried to animate them. One model Cam_1 worked perfectly, but the second one Cam_2 didn't.
Have you any idea what I did wrong?
davebYYPCU
Can't see much difference between them, slider joints are on differing faces,
but this is a good demo of contact set reliability, or not.
Might help....
JB_SGGW
Thanks for replay.
If on your computer animations work well that means the problem could be with my computer or internet connection or both.
jhackney1972
I would not judge your computer on this model.  One of your assemblies works well, the other does not.  I am using a very old computer and by no means do I judge the performance of it on a Fusion 360 Contact Set.  They can be very unpredictable.  By the way, sometimes the sequence you apply your joints will determine if the Contact Set works or not.
John Hackney, Retired
davebYYPCU
Nothing wrong with your computer, lots of contact set anomolies documented in here, avoid them if you can, but needed for this model.
Might help....
JB_SGGW
Thank you for your reply and help.
JB_SGGW
Thank you for help.
