Construction planes????
charlescooke58
charlescooke58
I need to put a f...  CP where the blue line intersects the upper deck, I dont know the measurement and I cant measure it, inspect is pathetic and why is it so f... small. I have seen on videos how they move adjust the size, rotate it and position it where they want, but I cant do it???Screenshot (13).png
g-andresen
1. in the future, refrain from using expressions like f...
2. planes are based on faces, edges, corners... and define e.g. the xy-base on which the z-axis is arranged perpendicularly.
3. 3 profiles meet at the tip of the bug, and can be the basis for a plane. Which one is suitable depends on what is to be created on the plane.
4. the timeline shows a large number of warnings and errors that make further work difficult or impossible.
günther
jhackney1972
You did not supply your model so it is hard to give you an exact answer.  If you need some help is the creation of Construction features take a look a this blog article and video.
John Hackney, Retired
jeff_strater
you can adjust the size of the plane by dragging the corner points or edge lines.
And, as @jhackney1972 says - this is a professional forum, please keep the discussion professional.
Jeff Strater
Engineering Director
charlescooke58
Thanks for that now let me try it, because it would reeeeally help to know if a cp is passing through a point. Apologies to all in future I will calm before asking help.
