About a week or so ago, all construction lines in the design space have started causing Fusion 360 to have severe hitching issues. If I try to draw a circle, or more than a single line with construction mode turned on, the entire program starts to have severe hitching, even on other projects/designs, as long as the offending sketch is open. Also, the construction lines in question will be invisible, with only the centerpoint/endpoint showing. Finishing the sketch does not resolve the issue, only deleting the construction line does. Drawing a regular line and then converting it to construction causes the same issue.
I'm running Windows 8.1 with 8gb of ram, I5-4690k, and a Nvidia 1060 6gb.
Any help would be appreciated, as I am severely limited in what I can do without construction lines.
