Constraints Are Breaking
tony9RBDC
Observer Observer
tony9RBDC
Observer
Observer
Why do the constraints work fine within the Edit Constraints tool...(see below)
....and when I click OK the constraints break...(see below)
Everything worked fine until about 30 minutes ago. I restarted the computer. I deleted the parts and re-imported them. The same part keeps breaking. Again, it worked fine until recently, and I didn't change any settings.
g-andresen
please share the f3d  file for reply
günther
jhackney1972
It is hard to diagnosis without your model.  Please attach it.  Open it in Fusion, select the File menu, then Export.  If it is a F3Z file you may have to ZIP it in order to attach it.
John Hackney, Retired
tony9RBDC
Observer
Observer
Thanks. Attached.
jhackney1972
You must have one of your assembly components Grounded to Parent for the Constraint to work properly.  The Video will show this.
If this answers you question, please mark my post as the Accepted Solution, or ask further questions.
(view in My Videos)
