Constraining an odd shape
tjstichberry
tjstichberry
Community Visitor
Community Visitor
I'm trying to constraint and define the following sketch but I've only been able to constrain the bottom line so far. I'm now stuck and would like some help with defining the rest of the sketch.
The polygon constraint has not worked. All points have the coincident constraint. All edges have dimensions. Bottom line is defined to be horizontal and coincident with the 0,0 point.Screenshot 2026-04-20 170829.png
TheCADWhisperer
@tjstichberry
Where are you getting those numbers from?
They don't look logical.
Is that point at the top supposed to be vertical from the Origin?
The endpoints of the bottom line do not appear to be constrained to me
Click and drag line endpoints.
What do you observe?
What are you attempting to model?
(view in My Videos)
rohit.bapat
Hello @tjstichberry
just a thought, have you tried "Auto Constraint" command yet? That might help you.
Also, with the f3d file we can help better.
Thank you
Rohit Bapat
Sr. Product Owner
rosie_lucas1
Hello @tjstichberry,
I just wanted to check in to see if you saw @TheCADWhisperer and @rohit.bapat follow up request and questions. Are you still needing assistance? Or did you find a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
Rosie | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Rosie
