connecting lines
connecting lines
reevesnicholas
Message 1 of 9
connecting lines
reevesnicholas
Im new to autodesk fusion 360.
I started to make a sketch, and there is a few things i cant seem to find or do.
The line wich I made a construction line, how do i connect the horisontal lines to the half circle. So they become one continiouse line.
I also want to mark points of specific length through the construction line. My issue here is that i want the length to go paralell to the circle, not in a straight. Is this possible to do?
Ill put a picture to illustrate.
Replies (8)
Message 2 of 9
wmhazzard
There are no horizontal lines in your image so it is not clear what you want. Can you draw with a pencil and paper what you want.
I see several lines that have the same dimension, it is better to dimension one line and use the equal constraint to make all of the lines equal.
Message 3 of 9
reevesnicholas
Thanx for the feedback!
My bad, i meant the vertical lines. The one from the bottom that connects to the half circle.
Ill put another picture up, maybe you can see what i mean here 🙂
Message 4 of 9
wmhazzard
I think that you want to use a 3 point arc instead of a line and that you want the length of the arc to be 26. There is no way to directly dimension the length of the arc in a sketch but is can be done with a driven dimension and formula in a parameter.
See this post, it may help.
https://forums.autodesk.com/t5/fusion-360-design-validate/can-i-set-the-length-of-an-arc/m-p/1093501...
Message 5 of 9
g-andresen
If you would say what you want to achieve in the end, we could give more specific hints and help to avoid unsuitable ways.
Günther
Message 6 of 9
reevesnicholas
thanx!
I will check these out 🙂
Message 7 of 9
reevesnicholas
Good idea!
So what i want is the length from A to B. Say the total length is 260mm and I want to split up the length 10 times. Thats 26mm each section, but doing it the way i have done it I end up having example 270mm total.
I guess I have to do the formula in parameters.
Message 8 of 9
TheCADWhisperer
@reevesnicholas
Why it this thread marked solved -  you haven't solved your issue.
Unconstrained (blue) lines should drive you crazy - you shouldn't be able to sleep at night with blue lines.
Check back in a few minutes...
If you want distance from a to b to be a certain distance - then logically it would make sense to dimension that distance.
Notice that my sketch is black (fully defined).
Notice that the 10 arcs are equal length...
Message 9 of 9
TheCADWhisperer
@reevesnicholas wrote:
That's 26mm each section... 
No, no it is not.
Not if you want equal length arcs.
Are you after arc length or are you after chord length?
