configure micro boring bar
Hi everyone , i am new to Fusion 360 and trying to configure a 3mm micro boring bar (turning)in the tool file obviously it is a ground solid bar with no tip to configure .Also how do you set up for machining an  internal bore many thanks in advance.
paul.clauss
Hi @Anonymous
Thanks for posting.
Internal Boring can be achieved though the Turning Profile toolpath with the turning mode set to "Inside Profiling." Turning tool definition visual previews in the tool library are defined from the perspective of a toolroom lathe, so keep that in mind. The tool will appear flipped in a slant bed lathe, but the posted code will be the same.
This video on internal boring may be helpful.
Fusion 360 does not currently allow for boring bars with no tip and you'll need to create a boring bar with a tip that matches the geometry of your physical tool as closely as possible. If you can share details on the tool you are working with I am happy to give it a shot!
Paul Clauss
Product Support Specialist
