Computer upgrade
Computer upgrade
jerryc80
Observer Observer
Computer upgrade
jerryc80
Observer
Observer
I am currently running Fusion 360 on a Toshiba Satellite A665-S6086.  It hangs when I design complicated parts especially when inserting SVGs with high point counts.  I am looking to upgrade to a Dell Inspiron 3000.  I included spec of each below to see if you think it is worth upgrading to this model or I need something better.  I don't have experience with the Vega 6 graphics or the AMD Ryzen CPU, wanted to make sure they worked well with Fusion.
Model Name: A665-S6086                                        Inspiron 17 3000 Laptop
Operating System
Windows® 7 Home Premium 64-bit        Windows 10 64 bit
Processor and Graphic
Intel® Core™ i3-370M Processor        AMD Ryzen™ 3 2300U Mobile Processor with Radeon™ Vega 6 Graphics
o 2.40 GHz, 3MB Cache
Mobile Intel® HM55 Express Chipset
Mobile Intel® HD Graphics with 64MB – 1696MB dynamically allocated
shared graphics memory
Memory5
Configured with 4GB DDR3 (max 8GB)        8GB, 2x4GB, DDR4, 2666MHz
Storage Drive6
500GB (7200 RPM); Serial ATA hard disk drive                                                   1TB 5400 rpm 2.5" SATA Hard Drive
TrippyLighting
Fusion 360 is notoriously slow with imported DXF and SVG geometry when that includes many sketch elements.
Buying a better machine will only marginally improve that.
jerryc80
Observer
Observer
With the current machine I have problems with slow graphics in most designs, svg's are locking up the machine, just wanting to see if anyone has used the inspiron and had good results.
g-andresen
The best way: try to test it with a Fusion Setup on the Inspiron.
If you have a look at the hardware requirements you ´ll see there are limitations with some Intel on Board graphic systems.
günther
