Compute unresolved components - red alert mark
simons734CCKYR
simons734CCKYR
Hi Community,
I nearly tried everything to get rid of this red alert.
After compute unresolved it tells me "Design looks fine. No unresolved components detected."
I the same Project folder I cannot insert this design in another, it tells me then "Must be from the same hub"
Regards, Simon
simons734CCKYR
See attached
cooperolivia919
Try moving the problematic file to the same project or hub as the one you are trying to insert it into, then reopen Fusion. Once everything is properly synchronized, the red alert should disappear.
