Components vanishing
Obadare
Obadare
HI,
I have just now lost two components and the contents of two other components within the one file, this happened has happened twice on the same drawing.
g-andresen
Maybe there were actions in the timeline.
Please share the file
File > Export > save as f3d on local device >attach to next post
günther
Obadare
Yes, it seems if you move the timeline on a particular component it can hide other component that have been projected.
nigel76FS8
Another problem is if you are using the (awful) joint system, and Contact is turned on, you can "bump" through the other components and the "missing" part has simply jumped away into space somewhere. Hit Undo to bring it back - you can't drag it back, as it will hit the other bodies and stay out there!
Or are they missing from the timeline/lefthand folder system too?
Obadare
Yeah missing from the left hand folder, when you active a component that is linked some how they pop back up. I freaked out the first time it happened and after starting one of the components again they popped back up.
