Component locations after modifying
mitchcaldwell
mitchcaldwell
I have designed a simple box which I intend to cut with a laser.
I have designed it, or had hoped to design it, to modify the width, length, height and material thickness so I could quickly/easily alter the dimensions for different applications.  The box utilizes box joints, which modify themselves based on the length/height/width of the box.
After designing the individual components, I then flatten them out using the move function (Point to point), then create a DXF file to export.
My issue is that after I modify the dimensions of the box, my parts shift to (seemingly) random positions.  My thought is that I point-to-point the parts based on sections of the box joint which might alter, or disappear when the parameters get changed.  Unfortunately, I don't know how to accomplish my goal.
My background in Fusion is self taught for hobbyist purposes.  I know enough to be dangerous. 😊😥
Any help would be appreciated.
rohit.bapat
Hello @mitchcaldwell
Can you please attached the model? It will help us analyse the issue better
Rohit Bapat
Product Owner
