Component goes unselectable when entering "create form"
Working on "Rapid frame concept" course,I am stuck at lesson 7 step 6 coz When I enter "create form",the component goes unselectable and I can no longer edit it or merge it with another component.The create form mode seems to deactivate it.The only way I can get it back editable is to save the file in create form,but therefore,the others components become ghosts again,so no possible merge or bridge...I tried to convert it into T splines,it worked but was not editable! Anyone that have the solution to this issue.Sorry by advance,pretty sure this is a mistake I did,but I could not figure it out.
Phil.E
I'm not familiar with that tutorial. Can you post a link or help me find it so I can see the instructions? It would also help if you could post a screenshot of the entire Fusion window after entering create form.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Hi,sorry for my late reply,I could figure it out,I did not pay attention where I put the bodies when I entered "create form" mode...So I started over and it was fine...So I guess that in order to merge 2 sculpted bodies,they have to be created and placed in the same component..and best way to log off and resume your work after logging in is to save the file while still in create form mode(unless you can get it back in edit mode from the timeline).
Apparently,in conclusion,2 bodies can be joined in create mode if they belong to two different components...unless I don't know the trick yet,since I am quite a beginner still..Anyway thanks for your help 🙂
