Compenent 'explodes' when copying...
andrew.smithPWL2Q
andrew.smithPWL2Q
This is something I stumble upon all the time, that is causing me quite some frustration. I have a component consisting of a number of subcomponents - I guess it is referred to as an assembly? - ...
When I try to duplicate the component using the move tool and checking the 'create copy' box, everything seems fine right up to the moment where I hit 'ok' ... and then: Kablooey! some of the subcomponents are strewn about seemingly randomly.
I have this issue all the time and don't know what I'm doing wrong. The video shows an example of what I'm referring to:
I'm pretty sure that this is all my fault, but would like to know where I'm going wrong... 🙂
Best regards,
Andrew
jeff_strater
Not easy to diagnose without a sample design, but a couple of things to check for:
  1. Do you get the same behavior if you just Copy/Paste the sub-assembly component involved?  In theory, Move with the Copy flag check should do the same thing, but worth checking.
  2. I notice that you have some un-captured component moves in this design.  If you Revert or Capture those moves, do you get different behavior?
  3. Is this sub-assembly component fully self-connected with Joints?  That is, you are using rigid or other joint types to position the components in this sub-assembly, as opposed to using Move or Align (which do not capture associative relationships between component geometries).  Jointed assemblies will always behave better than those without Joints.
Jeff Strater
Engineering Director
