Comments not working
DLP_Graphics
Message 1 of 8
DLP_Graphics
Whenever I try to open the comments tool add a comment to a file I get an error "Your file was not found - it may have been moved or deleted. ERR_FILE_NOT_FOUND"  It doesn't work on any of my files.
Replies (7)
Message 2 of 8
jodom4
Hey @jeremy_lambert, can you offer some insight here?
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 8
Hi there dlpGVFNN, did you by chance transfer this project from another hub?
-jeremy
Message 4 of 8
DLP_Graphics
Hi Jeremy
Its the same for all my projects. I don't think it has ever worked for me. I would like to be able to use it.
Message 5 of 8
jeremy_lambert
OK, it's not clear to me what the underlying issue is which is causing the error. I'll direct message you and see if we can't get on a call to take a closer look.
Message 6 of 8
tylerjoh
Did this issue ever get fixed? I'm having the same issue (Mac OS, v 2.0.12888)
Message 7 of 8
jeremy_lambert
Hi @tylerjoh, it seems the issue was that the session of Fusion 360 was in offline mode. You may want to check and see if Fusion 360 is online.
-jeremy
Message 8 of 8
nilloc
I also encountered this problem on all projects. I was working online, however there was a pending update. After installing and restart comments were available again.
