combining bodies question
gdcm1964
gdcm1964
Is there a way to combine 2 bodies that will put them parallel on the same plane? Like the tool in prusa slicer that will put the model flat on the table.
I use the move tool but getting them parallel using my mouse isn't giving me the control I need to get one perfectly flat on the other.
I've tried the combine tool and it does combine them but in the orientation you have them in.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
jeff_strater
Align is probably what you are looking for.  However, it would be good to understand what problem you are trying to solve, because Move or Align are not recommended for most general workflows.  They have their place, but should not be used as a replacement for defining components and using joints to establish relationships between those components.
Jeff Strater
Engineering Director
gdcm1964
this is what I'm working on. key racks for friends bikes. I've placed the silhouette of the bike on the rack using the move tool but getting it to sit flat on it is the challenge
g-andresen
create components and join them
günther
gdcm1964
thank you very much. I didn't know you could drag and drop bodies like that.
gdcm1964
aaaand I'm back. lol
I did the create a component step and it joined the two components like your video did but one side of the logo is washed out.
I double checked and it's sitting flat on the plaque.
