combine tool is not working
norgmonster
Message 1 of 55
norgmonster
I've spent the last 3 hours trying to combine a body with a sheet-metal body. I've done this a 1000 time on similar projects with it working fine.
Now, when I try it says:
Error: There was a problem combining geometry together.
If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
Failed to Boolean bodies together
I also get error messages like:
Error: inconsistent edge-face relationships
Both sides to join are flat and the same size so I don't know why it would be having an issue. I'm also not a stranger to fusion so have tried a number of things.
Can someone please help?
Jonny
Replies (54)
Message 2 of 55
g-andresen
only from the pictures it is not possible to give hints.
Please share your design.
günther
Message 3 of 55
norgmonster
How do I share my design?
Message 4 of 55
g-andresen
File > Export > save as f3d locally > attach to next post
günther
Message 5 of 55
norgmonster
The .f3d file comes out at 274mb. Is this normal?
From the screen grabs you can see it’s not that complex.
Your thoughts?
Message 6 of 55
norgmonster
I am now getting  this error message:
Message 7 of 55
jhackney1972
Go ahead and Attach you model to a post.  If you do not know where take a look at this screen capture.
John Hackney, Retired
Message 8 of 55
norgmonster
As i said, the file is over 270mb so it won't fit in an email or an attachment hear.
What should i do?
Message 9 of 55
jhackney1972
I guess you either can cut out the section in the original file that is giving you issues and post it or you could go to your data panel and share a public link.  If you do that, make sure your check the box to allow download.  Once you have the public link, given to you during the process, post it to the forum.
Message 10 of 55
norgmonster
This is a public link:
https://a360.co/3jnjX1s
Let me know if it works.
Message 11 of 55
jhackney1972
Link is good, downloaded.  Now you mention a sheet metal body that you are trying to combine to what?  There is only one sheet metal body but your pictures and description do not tell what you are trying to combine to.
Message 12 of 55
norgmonster
I'm trying to connect "body61" to "body63". For some reason, I was able to connect one of the end pieces to the central shaft. when I did this, the "sheet metal body" was converted back into a normal body.
Message 13 of 55
jhackney1972
I have tried every trick I know but I have not found a workaround to the main body inconsistency.  I hope someone else can find the issue not only for your design, I would like to learn something.
Message 14 of 55
g-andresen
After a few minutes of waiting, I felt like a waitress on the sinking Titanic, checking the correct arrangement of the cutlery on the tables in the saloon.
My tip: warnings in the course of a design should be followed up immediately, but at the latest with the next following error message.
günther
Message 15 of 55
norgmonster
Hi Gunther,
I don’t understand what you are saying.
I did not get any warnings, just an error message.
Do you have a solution to the issue?
Do let me know.
Message 16 of 55
TheCADWhisperer
Are there any unresolved issues (highlighted yellow or red) in you Timeline?
If so, why?
Message 17 of 55
TheCADWhisperer
This entire modeling process does not look efficient to me.
For example, the first 5 features could have been made with one Extrude with Taper feature, in position with no Moves.  This is a simple pattern. Forget Move (and Align in this case).
I recommend that you do not use Combine where ZTG (Zero Thickness Geometry) would result.
Message 18 of 55
g-andresen
1. the occurrence of warnings (yellow) and errors (red) can be seen in the timeline.
2. while connecting the bodies I guessed a bit, because I had not found body 63.
I did the connection of the elements from #1 with the point to point variant.
günther
screencast
Message 19 of 55
norgmonster
Ok.
What I don’t understand is why it was not combining for me?
I’ve done similar projects and never has an issue with connecting bodies together.
How can I stop it from happening again in the future?
Jonny
Message 20 of 55
jeff_strater
I have not had time to open the model yet, but just looking at it in Fusion Team/A360, I can bet what the problem is:  These kinds of errors happen in Combine with "nearly contiguous" geometry - you can tell from the Z-fighting here that you have some bodies/components that have faces that are pretty close to the same, but may vary a tiny bit from each other:
this condition will often cause those kinds of errors.  If you are positioning bodies using Move, if they are not positioned extremely accurately, that will cause problems.
Jeff Strater
Engineering Director
