Combine Tool: Inconsistent behavior
FrodoLoggins
Advisor Advisor
FrodoLoggins
Ok so I've got 2 bores that are the same diameter:
If I boolean both holes with the same tool body and in the same manner I get two different results:
Screenshot 2023-08-24 at 10.05.45 AM.pngScreenshot 2023-08-24 at 10.06.13 AM.png
Yes 3 tenths difference is too much.
All geometry modeled in Fusion.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
TrippyLighting
I note that you move the cutting body in by different amounts:
ā€ƒā€ƒ
FrodoLoggins
Yes. That is because the cutting tool was farther away from the bore the first time. The tool sits inside the bore the same amount both times (.0175")
For demonstration purposes/double checking I first moved them so the start of the taper was flush with the top face  (this value was different because it was arbitrary) then moved them both .0175" inward.
Screenshot 2023-08-24 at 3.23.49 PM.pngScreenshot 2023-08-24 at 3.26.21 PM.png
TrippyLighting
If I use the align tool first to align the cutter with the bore and then move it in a consistent amount, I get the same consistent result.
Relying on measured results is sketchy. At the very least I would enable all digits and then click on the measured value in the UI, which copies the value to the clipboard.
FrodoLoggins
That's cool dude.
