Combine to create new component & Keep Tools = continual blue highlight
jlcreations3d
jlcreations3d
With the most recent update, now if I use the "Combine" tool to create a new component and use the option "Keep Tools", Bodies within that operation (sometimes it's the base object, sometimes it's the tool - it appears to depend on the operation) will stay continually highlighted blue even it they are no longer selected, or even if that body is hidden.
If I uncheck "Keep Tools" this behavior does not occur, or if completely turn of the bodies or component the object is in, otherwise it requires a complete restart of F360 to go away.
jeff_strater
I'm not seeing this.  Am I doing something different in the video below?
Jeff Strater
Engineering Director
jlcreations3d
You did not select "New component" anywhere that I saw.
jlcreations3d
Hopefully this shows the steps well enough!
g-andresen
I see this
günther
jeff_strater
ah, OK, it seems to be to combination of:  Join, Keep Tools, and New Component.  Cut does not seem to have that problem.  Thanks for the clarification
[edit] created bug FUS-142687 for this
Jeff Strater
jlcreations3d
EDIT: Yes, the highlighting did only show up on the join operation.  I thought I had experienced it with Cut, but I was mistaken.
Thank you for your response!
