I have imported a step model of a PCB, I need to combine all of the components then export to an stl for 3d printing. The problem arises at the combine stage. I have a board that fails 100% of the time to combine, prior to this morning, it failed silently (acted like it was combined, but left many components uncombined). Today it fails every time with the message "null pointer to body given". I have attached an example .step file, if you import this model, then attempt to combine all of the parts to the board you can recreate the error.
I'm looking for suggestions to push this through, working with these designs is our primary use for Fusion 360.
