Coincident constraint is not able to create a closed profile with an offset - Fusion
acpigeon
acpigeon
This is very strange. I have two ellipses, one drawn directly and the other an offset. I am trying to use lines to cut a slice out so I can build a clamp. If I constrain the lines to the outer ellipse it will not create closed profiles. If I extend the lines beyond the outer ellipse without constraints, it creates the expected closed profile. Screen recording of the behavior, and file attached.
This post has been edited due to: @heather_tracy added the product to the title to help more community members find this topic.
TrippyLighting
My recommendation would be not to constrain any other sketch element to any offset geometry. Offset sketch geometry often creates problems in sketches,  particularly when combined with an ellipse or spline. @rohit.bapat
If you create the outer ellipse first, and then offset to the inside, and then constrain the line endpoints to the original outer ellipse, things work as expected.
HughesTooling
You should either intersect this surface to create the projection or use the original ellipse in the sketch for the other component (rather than project complex edges) so you get an ellipse rather than a spline in your sketch.
Using the projected ellipse still creates a spline for the offset but you no longer see the problem with the profiles not being closed. See attached file.
Mark Hughes
Owner, Hughes Tooling
dsouzasujay
Hi @acpigeon
Agree with @HughesTooling
As a workaround, you can 'Break' the sketch, shared in below video.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
acpigeon
Thanks, yes this works also.
acpigeon
Thanks, I didn't realize offsets were problematic.
acpigeon
Thanks, I didn't think of using the sketch geometry instead of the surface.
