Clicking menus requires more than two to three clicks before the menu stays open.
2.0.8749 just installed on macOS 10.15.5, and now I'm experiencing a bug that has me tearing my hair out.
While in Design mode, if I click on the CREATE drop down menu, it'll slide open, then slide closed immediately. Click it again, same thing. Click it a third time, it stays open.
Sometimes it requires 3 clicks, sometimes it requires 4 or 5. It happens with the icons in the far upper right corner as well.
I thought perhaps my mouse was at fault and was double clicking or something stupid, so I did a few things:
Using ControllerMate (excellent software that's you program behavior for most input devices) I tried two things:
I setup a counter for mouse clicks. It just tracks clicks and allows the original mouse behavior to continue. I saw that for one click on a menu item, I'd count one click of the mouse. The Fusion 360 menu items would behave as I describe above, opening and immediately closing for a single mouse click.
Just to be certain, I programmed some debounce into the mouse using ControllerMate so that my mouse would ignore any clicks made within 500ms of the last click. You'd never want this in real life, but it works well if you suspect there are debounce issues.
That said, the menu behavior I describe still happens.
Restarting Fusion 360 has no effect on the behavior, nor does restarting my machine.
