Circular Pattern Componet Joints not included
tony.riosWAFEJ
tony.riosWAFEJ
I'm creating vise assembly and when using Circular Pattern for a component the joints created aren't transferring over to the new components. I can grab the vises and move them around, is there a way to do this without grounding the new components?vise.png
jhackney1972
A pattern is basically a copy of components and joints are not included as part of the pattern.  Once the pattern is complete, you could use an As Built Joint, the type of your choice, to joint them back into the assembly.
John Hackney, Retired
tony.riosWAFEJ
Thank you, I was afraid that was the answer. I'm an Inventor User and the assembly in Fusion is not very good anyways thanks!
jeff_strater
There is a project being planned now to allow components to be copied with their joints.
Jeff Strater
Engineering Director
