Circular Dependency
Circular Dependency
moriarty.chch
Circular Dependency
moriarty.chch
Im plagued with circular dependency issues ...
Ive attached a knocked-down file that still exhibits this behavior
.... if you load it then Compute All (Ctrl+B) you will get circular dependency.
Whilst with the error, delete Draft6 and the following Deletion Warning occurs
Cancel and go back to the original setup 2x UnDo
Cntrl+B still crashes it ... UnDo
Edit Draft6 and just click OK - model builds OK
Try Cntl+B ... crashes
One fix is delete Draft6 and remodel it - sometimes this works and sometimes it doesnt ... the fault can come back with a different tool so is probably something other than the draft.
2.0.6670  Win10
TrippyLighting
The extrusion of the half circle is set to "join". If you set that to "New body" and then delete and re-apply the draft this will remove the circular dependency. Maybe also fully constrain and dimension that sketch 😉
jeff_strater
@moriarty.chch - thank you for cutting down the file to such a small timeline.  That really helps us.  This does show a bug in Fusion that has been logged as FUS-57844.  We will look into a fix for this problem.
Jeff Strater
Engineering Director
moriarty.chch
thanks for the input everyone
You can    Edit and OK    the Draft, Extrusion and Sketch elements
If you try and do this with Moveface it throws a circular dependency error straight away
looks like theres some issue with Moveface
