changing round hole into a D shape hole
duoro2
Observer Observer
duoro2
Observer
Observer
how do you modify an existing round hole to having one flat side ('D shaped hole) ? Thank you.
davebYYPCU
Draw a line across the circle.
Might help….
duoro2
Observer
Observer
Thank you, I did that, but not sure how to extrude & fill the area, the full length of the hole.
davebYYPCU
Extrude - select the new segmented sketched area, set depth, set Join.
(Requires the sketched circle and line in the same sketch)
Might help…..
duoro2
Observer
Observer
Sorry for delay in replying, I have not had a chance to try your suggestion yet, been busy.
duoro2
Observer
Observer
I solved the problem, since the hole had a flat bottom I placed a thin rectangle @ the right width on the base of hole, attached it & then I extruded it up the hole.
