Changing point of view causes max unzoom
sebastien_privat
sebastien_privat
I'm designing a B-52 engine nacelle.
I know I have moved the piano rather than the stool a couple of dozen times, but I'm facing an annoying issue.
When I clik on the up/right/left/etc. button in the top right of the screen, the view unzooms to the max.
Do you know what causes this issue, and what can be done to prevent it?
TIA,
Sebastien
jeff_strater
hard to say without the design in question.  Usually there is some object that has been inadvertently placed a long way away from the origin, and the view zooms out to include it.  If you share the model, we can investigate.
Jeff Strater
Engineering Director
sebastien_privat
This curious behaviour has stopped after I clicked a couple of times on the cube (first to have a view from the rear, then on the triangle to have a side view).
I re-zoomed, and it stayed put.
Here is my model.
I accept all criticism about it.
Cheers,
Sebastien
sebastien_privat
Oh, and I have a some hundred meters and change long line, and I haven't the faintest idea on how I made it...
S.
