Changing design origin position to another point of design
FLEXINGROUP
FLEXINGROUP
Hi, I would like to ask you if it possible to changing design origin position to another point, for example:
I insert some components and joint them. And i would change a design origin position without move the components, so without change the position of rigid group.
See attachments.
jeff_strater
you cannot "change the origin position" of a design - that is fixed in world space.  However, you can move the design elements (body, etc) to the current origin.  Also, you can create Joint Origin objects anywhere, to help you create joints to this object.
Jeff Strater
Engineering Director
