Changing an ISO drawing sheet from A4 to A3.
I have made an ISO drawing on an A4 sheet, but now want the same drawing to be on A3. I have explored fusion settings, but haven't found anything of help. Any help would be greatly appreciated. Thanks!
MoshiurRashid
Thank you for posting. For solution, you should go to the "Preference". Then, click on "Drawing". After that select the Standard and Sheet Size. Hit Apply and then Ok. That will do it.
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
neilstrbooysen
Does this change all the drawings ive made to the selected preference?
I did this but saw no change in the document.
jhackney1972
I think this is what you are looking for.
John Hackney, Retired
rohit.bapat
Hello @neilstrbooysen
If you change the setting in the preference, it won't change the sheet sizes of previously created drawings. You will have to open those drawings and change the sizes for the sheets individually.
Thank you,
Rohit Bapat
(Product Owner)
Rohit Bapat
Sr. Product Owner
