Changing active units of measurment
harwoodjordan
Observer Observer
Message 1 of 8
harwoodjordan
Observer
Observer
Hi first post hear.
Is there a way to change the active unit of measurement with a keyboard shortcut? If not is there a way to set it up to do  this?
I have disability it make it hard to move keyboard to mouse easily and would be a big help if this is possible
Replies (7)
Message 2 of 8
CGBenner
@harwoodjordan
Welcome to the forum.
@Phil.E do you know anything about this?
Chris Benner
Message 3 of 8
Phil.E
There isn't a way to change units with a hot key currently. I'm looking into alternatives and will follow up tomorrow.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 4 of 8
harwoodjordan
Observer
Observer
Thank you. I appreciate it!
Message 5 of 8
Phil.E
This is what I found. It would require a custom add-in. The add-in would need to create two commands and place them in the toolbar somewhere.
One command would be for mm, the other for inch. Once you achieve this, a hotkey can be set for the command.
Here is the help section https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A
Unfortunately I don't know how to do this. There is a forum dedicated to it.
When you use the "Scripts and Add-Ins" command to create a new add-in, it creates a working add-in that provides the structure and a starting point, but you then have to add the specific functionality desired.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 6 of 8
graham.wideman
In case you still need to solve this issue, a user @kandennti has kindly provided such an add-in:
Sample addin to create button to set active units?
Message 7 of 8
HughesTooling
There is an add in in the app store that allows you to create hotkeys for any of Fusion's commands here.
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
graham.wideman
That's good to know about!  In this case, however, it has a slight disadvantage: The command to switch to mm is a different sequence of steps than the command to switch to inches. So that would require two hotkeys. Not fatal, but not quite as convenient as a single command, and hence single hotkey, that toggles between the two (which is what kandennti implemented).
But doubtless I'll have a use for the add-in you mentioned in future!
