Changes to one body not propogating to other instances in circular pattern
arcookeE4Z3W
arcookeE4Z3W
Hi
I'm trying to generate linked copies of a body in a circular pattern so that I can edit just ONE of them, and the changes will apply to all of them.  However, this is not happening.  If I change the first body, the other copied ones don't change.
Select body -> Circular Pattern -> OK -> Modify original body -> The change only applies to the original (copies don't change)
What am I doing wrong here?  I suspect it's just a workflow issue on my part
See attached video
Thank you 😊
arcookeE4Z3W
Disregard.  I just had to make my body into a component.  Solved!
KristianLaholm
The Timeline only works in one direction.
You have to do the changes to the body before the circular pattern in the timeline.
