change the radius
change the radius
mcnicollchris
Message 1 of 51
change the radius
mcnicollchris
hi there i need to alter the curves that are on the inside of this part, they need to have a radius of 5 to locate on my servo motor. i drew the square then tried to fillet but it gives me the opposite curve so i tried drawing a circle but that was on the wrong side of the bolt holes.
i know it will be something daft im doing.
Replies (50)
Message 2 of 51
jhackney1972
It is unclear what you desire.  You mention curves on the inside but all the curves in your model are controlled by the first sketch.  If you want to edit them, simply edit the sketch.  If you want to add 5mm radii to the sharp inside corners, use a Fillet.  If you could markup a screen capture to define your needs, I am sure someone can easily help.
John Hackney, Retired
Message 3 of 51
mcnicollchris
sorry i have taken a screenshot now
Message 4 of 51
g-andresen
please show a picture of the parts that will be joined together.
günther
Message 5 of 51
mcnicollchris
Here they are
Message 6 of 51
TheCADWhisperer
@mcnicollchris
Do you want to learn how to do this correctly?
(Correct modeling would require starting over and following explicit instructions.)
Tips:
Anytime you see repeated dimensions - you are probably working too hard.  Get lazy!
Anytime you see blue geometry - you should stop and ask questions before continuing on...
Message 7 of 51
mcnicollchris
Yes that would be great then I know how to do it rather than having it done for me
Message 8 of 51
TheCADWhisperer
Before we start - what is the purpose of these two lines?
Message 9 of 51
mcnicollchris
They must be duplicates
Message 10 of 51
TheCADWhisperer
Whenever possible and practical - make use of obvious symmetry about the Origin.
Create the two point rectangle to the right of the Origin as shown below...
Message 11 of 51
TheCADWhisperer
Add a Midpoint constraint between the Origin and the left side vertical line as shown below.
What do you notice about the color of the lines?
Message 12 of 51
TheCADWhisperer
Sketch the Construction linetype 2 point rectangle as shown below.
Message 13 of 51
TheCADWhisperer
Add a Construction line from the Origin to the Midpoint of the rectangle as shown.
Message 14 of 51
TheCADWhisperer
Add a Horizontal constraint the construction line that you just created.
(Tip: Your line might already be Horizontal in which case Fusion will tell you the constraint is not needed.)
Message 15 of 51
TheCADWhisperer
Add the 10mm dimension between the two left vertical lines in the two rectangles.
What do you observe about the construction line rectangle?
Attach your current *.f3d file here for next set of steps....
Message 16 of 51
TheCADWhisperer
Add a Centerpoint rectangle and dimension as shown.
Attach the file here for next step...
Message 17 of 51
TheCADWhisperer
Add the second 50mm x 50mm Centerpoint rectangle on the right as shown.
Attach your file here.
If at anytime you run into trouble following these steps - STOP and ask questions.
Message 18 of 51
TheCADWhisperer
So far we have sketched 4 simple rectangles.
Message 19 of 51
mcnicollchris
Sorry I’m at work I will have to sit down tomorrow now and do this
Message 20 of 51
mcnicollchris
part 1 is here
