can I Change the blue coordinate direction in joint function?
Yes, create a Joint Origin using the Joint Origin command. When placing the Joint Origin you will see a Reorient option in the dialog box. Once you have the Joint Origin established and reoriented, you use it as one pick in the standard Joint command.
John Hackney, Retired
I did not hear back from you on my proposed solution. If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask.
