Change Parameters + Scroll = Crash
I've encountered a repeated bug where, if I open the "Change Parameters" window and then immediately try to scroll down, the program crashes.  This has occurred in multiple different models and with two different (logitech gaming) mice.  I haven't tried it with other mice yet.
Needless to say, this can cause a bit of interruption in workflow.
Phil.E
@Anonymous
Hi, taking a look at your crashes I see two reports from you. Thanks for sending those in and including descriptive comments, your post here is nice and clear too, so thanks.
The crash is related to UI widgets that run the dialogs. There are no recent reports aside from yours, and only a half dozen total. This tells me it's not a general problem. It also is more prevalent with OSX 10.11, which you are running.
Can you try a different mouse? That would quickly eliminate the Logitech. If it still crashes, please send in the CER and reply to this thread. I'll see it and we'll dig deeper. I don't recall many crashes associated with Logitech mice over the years, but now and then goofy things can happen with almost all mice. Since you mention two mice, it may be the drivers. Do you have the latest drivers from Logitech?
Thanks, sorry for the inconvenience. Glad to help.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
