Chamfering broken in latest version
gerry_kmack
gerry_kmack
More specifically, "Chamfer Tip Offset" is broken. If you set the offset to zero (0), the tip is offset ~.25". If you set it higher, the offset increases correspondingly. You cannot set it negative. I tried.  This makes it impossible to chamfer the inside of a small hole, among many other things. This happens with both the 2d Chamfer tool path, as well as 2d Contour.
This bug came along with the latest update (9/24/19), which I don't even want.
How can I revert to the previous version?
seth.madore
Can you attach a file that you are seeing this in?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
