Chamfer fragmentation
For some reason my second hole gets a fragmented chamfer. Both holes are the same size. See attached file and screencast.
masa.minohara
Hi @Anonymous,
Thank you for posting! This is strange and I'm not sure why this is happening right now so I'll investigate further. In the meantime, could you try the workarounds below to see if they help?
1. Use a loose tolerance
2. Select sketch instead of the edge of the hole
I apologize for the inconvenience and I'll circle back here as soon as I have more information to share! (CAM-8730)
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
