Center diameter mode is not working
spancheau
spancheau
When I try to use the center point and type diameter the diameter is not accepted. The diameter I drag to before entering the diameter wanted is what it places. There is a little yellow dart that I think means there is an error, but no description is given. I am using inch mode. I have always used this method before for making circles. I recently had to re-up my free subscription. Is this feature no longer able to be used with this subscription?
Scott
FacebookGroupMember
Windows 7?
seth.madore
Nothing in Sketch has changed for license types. Can you share your file? File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Also if you could, could you make a ScreenCast of your steps?
Seth Madore
spancheau
Thank you for your help. I realized that the computer I used is old windows 7 that I have never upgraded. I went to my laptop and all worked as it should  on windows 10.
Scott
